particle-particle/ particle wall collision efficiency
User: "Fatemeh Hosseini_22198"
Altair Community Member
Updated by unknown
Hello everybody.
I am studying the behavior of particles in a fluid in tube.
Its too important for me to know collision efficiency between particle-particle and particle-wall. Also the rate of deposition is important for me.
Is there any tool on EDEM for measuring these parameters?
Thanks a lot
1 - 1 of 11
    User: "Stephen Cole"
    Accepted Answer
    Updated by Stephen Cole
    Hi Fatemeh,
    You can use either the Contact information or turn on 'track Collisions'.  If using Contacts you only get the instantaneous particle-particle and particle-wall contact information at the save data point.  If using Track Collisions this will record the time-dependent collision, store this in memory and write it to file at the save data point.
    Track collisions gives you a lot more data however it uses more memory and is only supported on CPU not GPU.
    The track collisions option can be turned on in the EDEM Simulator tab.  Once you have this or are looking at Contacts you can export the data from the EDEM Analyst > File > Export Results data area.
    Regards
    Stephen
