Greetings everyone.
I am using Hypermesh2023. And I need to create a shell from 3d element. In old version, I can just do it by using Tools-Faces. But Hypermesh2023 dont have Tools-Faces. I wonder how to do it. Thanks
Hello,User can create the Faces for 3D elements from the Validate > "Faces" Ribbon.
Refer the attached image.Regards
Prajval
Hi.
I use this method (video attached) for remeshing/repair solid elements.
In the new HM we have Topology tab and FE Geometry from Elements.
Video I recorded - is the answer for your question - (it is a part of repairing solid el. process in my case. )
1. mark tetra elements (or other 3d)
2. create a FE geometry (Topology -> FE Geometry -> From Elements)
3. surfaces are created from these elements
4. mesh surfaces created by FE geometry
5. 3dfaces component of only 2d elements is created
I hope this helps
MK
