Hi Sourav!
1. Can be observed air pressure, air temperature and air velocity in mold?
2. I'ts possible to observe only the hottest areas in the mold (not only the coldest areas)?
Thanks in advance.
Best regards,
Hello ViV,
Sorry for the late response was out of office.
Answer
1. you cannot see the air related results in mold.
2. If you see the temperature of the mold, you should be able to identify the hot and cold spots. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Sourav
