Hello there,
I've been working on simulating wheatstubbles. For simulating the stubbles i've generated a meta particle and then bonding it with using a custom bonding modell via API. The bonded stubble meta particle is also bonded with soil particle with are generated afterwards. But depending on how many soil particles I generate, I get the error "possible data loss" during the calculation and the calculation crashes. With a soil particle quantity of 17.5 kg, the calculation runs correctly. But with a particle quantity of 30 kg, for example, the calculation is cancelled. The last available time step is then the one directly before the soil-soil bonds are generated.
I have attached all the files for this question.
Best regards
HE
