LIKE 'position' function in hypermorph .whether any option in morphing tool for transferring elements to components with our dimension or any related data.Exactly exact movement of elements to geometry not by moving with handles approximately
You can give a try with map to geometry option depending upon geometry.Hypermorh have four concept of morphing(Domains & handle,Morph volume,freehand &Map to geometry option)
Altair Simlab is also having some fantastic feature to modify existing design like creating ribs ,add & remove hole ,increase thickness etc.
Would be nice if you can show some snapshot of your requirement.
Regards
Rahul R
