Hello every one ,
i made mid surf in time automatically transparency decrees , how to control; that function , here i attached video that please check it .
if i made mid surf with out use toggle operation its work .
Hi Yukesh,
Can you try it by manually adjusting the transparency using geometry transparency tool?. Select the option from visualization toolbar or Ctrl + T.
If you select only 2 surfs -> it does not automatically make transparency
If you select more than 2 surfs -> it does
If you select 'toggled' 2 surfs -> same as more than 2 surfs (toggled surf has more geom indices)
I do not see any option to control that. If you want to do it, set a callback proc to *midsurface_extract_10
