Hello all,
Is there any way to import .t16 results generated by Marc 2017 solver into Hyperview?
HvTrans doesn't read Marc 2017 .t16 either. Marc 2016 results of the same model are read OK.
Best regards,
cjc
Hi cjc,
You can directly load the result file (.t16) into HyperView. If you find any issue/error, please share the error.
Thank you
Thanks for your prompt response,
The message is:
“Error loading results” for HvTrans.
For HyperView :
Warning: failed to verify file (C:\fea\faraday\test_marc2017_prl.t16) using reader 'MARC t16 Result Reader' Error: failed to read model from 'model' resource.
Error creating result math analysis [General]
If one tries to import just the model from Marc 2017 .dat file, the error message is:
Reader: MARC Model Input Reader....Error loading model. [General]
Both HV and HvTrans work ok if the same results are from a Marc 2016 run.
Hi @cjc
Which version of Marc and the results from?
Can you load the model file and result file and check if that helps?
Hi Prakash,
I have attached a test model ran in both Marc 2016 and Marc 2017 and the results for both versions.
The 2016 results import as expected ( Load model: filename2016.dat, Load results: filename2016.t16)
The 2017 results failed to import in any combination. The model from the .dat file (Marc 2017 deck) comes in as one single collector but the results, I wasn't able to import.
The HM version we are using: hwAcuSolve2017.2 hwAcuSolve2017.2.1_hotfix hwDesktop2017.2 hwDesktop2017.2.2_hotfix hwSolvers2017.2 hwSolvers2017.2.3_hotfix
Results from Marc 2017 are not supported in HyperView 2017+
An enhancement request is placed for the same.
Hi All,
Why this issue is still not resolved?
The issue is present still in HW2020 version. The same model computed in Marc2016 is imported without problems in HView 2020, but when it is solved in Marc2017/2020 the error occur when importing into HView 2020.
Kind regards, Pawel
