Simple Question - Does Hypergraph have feature to assign keyboard shortcuts to run TCL scripts
Hello everyone, I am working on a TCL script for a particular functionality and logic part is working properly. I wanted to know if I can assign a shortcut key to run the script directly instead of doing Run Tcl/Tk Script -> Selecting File.
As far as I know, hypermesh has this feature but could not find it in Hypergraph. Any help would be appreciated.
Edit: No worries - I am using bind and source commands now so the issue is solved.
Edit: Even though using bind and source helpful, both are them are Tcl/Tk commands so I need this script first to assign shortcuts. So this is good solution but better would be to assign permanent shortcuts, is that possible ?
what is the bind and source command?
Bind and source are Tcl/tk commands, source is used to run a tcl file and bind is used to assign an action to an event like pressing a button.
Hello, nice to meet you.
Wouldn't it be solved by writing a Tcl/Tk command that sets the binding in "hmcustom.tcl"?
https://2021.help.altair.com/2021/hwdesktop/hwd/topics/getting_started/hmcustomtcl_r.htm
best regards
