Hi all,
I am checking the contact model used in the software. But I find the contact model in the EDEM help file, where the damping coefficient is different from all the references listed. I can not understand what is the constant item at the begining of the expression of Hertz-Mindlin (no slip) model. Can anyone explain or give me a reference about this?
Thanks!
https://2022.help.altair.com/2022.1/EDEM/index.htm#t=Creator/Physics/Base_Models/Hertz-Mindlin_(no_slip.htm&rhsearch=damping
Hi Chandler,
You can find the references for the EDEM models here:
https://help.altair.com/edem/Bibliography.htm
Regards
Stephen
Hi Chandler, You can find the references for the EDEM models here: https://help.altair.com/edem/Bibliography.htm Regards Stephen
Hi Stephen,
Thank you for the reply.
I checked those references, but I didn't find this expression used by EDEM software in those papers. Can you please give a specific reference where the damping coefficient that I attached in the previous question comes from? We need it when we are writing papers about the simulation by EDEM.
Best
Chandler
Hi Stephen, Thank you for the reply. I checked those references, but I didn't find this expression used by EDEM software in those papers. Can you please give a specific reference where the damping coefficient that I attached in the previous question comes from? We need it when we are writing papers about the simulation by EDEM. Best Chandler
You can check:
Ning, Z., Ghadiri, M.: Incorporation of Rayleigh damping into TRUBAL and determination of the critical time step. (1996)
or
Abbaspour-Fard, M. H. ( 2000). “Discrete element modelling of the dynamic behaviour of non-spherical particulate materials.” PhD thesis, University of Newcastle, Newcastle upon Tyne, U.K.
This is helpful. Thank you very much, Stephen.
