I have installed the 2021 student version of the Altair sofwtware. As it is stated in the website, I set the ALTAIR_LICENSE_PATH environment variable to point towards the license file which was attached in a mail. Then, I can have access with no problems to the whole WinProp suite (WallMan, TuMan, ProMan...).
However, when it comes to the Feko suite, I am prompted a message which is attached in this message. I have checked and I do not have defined this FEKO_USER_HOME environment variable. I do not know whether this has anything to do with the fact that 2 years ago I had installed in the same computer another version of FEKO, the 2019 one. I do not have the file "2021.1_7b2b83fe", while I have one named "2019.3_393f94db" in the path that it states in that message.
Then, while I can normally have access to WinProp, I can not use FEKO.
I would strongly appreciate if you could help me with this issue.
