How can I apply angular force to my object? Can u explain or ı can share the file if you can do that.
Hi, do you mean a rotational force? The specific set up will depend on the solver you are using, you can add moments or rotational body forces from the 'Analyze' Ribbon e.g. for OptiStruct below
No, I mean force with angle. For example ı have force with 105 degrees. How can ı show the force like that? Also I use HyperMesh 2017.
There are multiple ways to do it. You can specify the XYZ components of the force when you create the load, or create a vector and specify its magnitude.
Thank u so much.
