Is it possible in hyperview to move the legend to the bottom of the screen and also make it horizontal instead of vertical? I only see 4 options in hv but none of them allow it to be horizontal.
Hi
It is possible to move the legend around from the options provided: Edit Legend > Position > Upper Left, Upper Right, Lower Left, Lower Right.
You can reduce the level instead.
Thank You
