Create macro for Automesh(F12) with "elem" selection entities
alpha_21885
alpha_21885 Altair Community Member
Hi everyone,
When I use Automesh(F12) to create FE modeling, I always have to switch b/w Elem and Surf.
I already checked *.cmf command but could not find the default setting for this to make macro.
I would like to create 2 shortcutkey: 'E' >> Automesh with element(remesh). 'S' >> Automesh for surface(new mesh).
Since I am newbies at TCL, hope any one can help on this TCL macro.
Thanks a lot!
Welcome!
  • tinh
    tinh Altair Community Member
    edited August 2014
    Hello
    as in hm12:
    proc press_E {} {
      hm_setcollector automesh 18 elems
      hm_pushpanel automesh
    proc press_S {} {
      hm_setcollector automesh 18 surfs
  • alpha_21885
    edited August 2014
    Hi Tin. Appreciate your help but your command does not valid on HM12. 'hm_setcollector automesh 18 elems'
    Anyway, it works on Hm11 and I already creates Switch Key b/w Surf/Elems for AutoMesh. No need to 2 shortcut keys!
  • Altair Forum User
    Altair Forum User
    edited August 2014
    at V12 you have to take item 19, e.g. 'hm_setcollector automesh 19 elems', but still a very good hint tinh !
    Mario
  • alpha_21885
    edited August 2014
    Really appreciate Mario for your help. It works with 19 but how do you know this number. If I move to HM13, 14 or HM10, HM9, what is number for this?
  • Altair Forum User
    Altair Forum User
    edited August 2014
    for me it was trial and error, since hm_setcollector is a undocumented feature.
    You can try it very fast inside the tcl command window.
    For release V13 it seems to be the same.
    Mario
  • tinh
    edited August 2014
    Heeeee
    The number is sometimes changed a bit although same version. I don't know why
    my hm12 is 18
    to get it exactly => you can dump the panel by
    hm_dumppanel automesh
    and looking for the number fore (ENTITY_COLLECTOR)
    from hm12, panels seem respond better. with hm11 i usually have to set timer when customize panels
  • Altair Forum User
    Altair Forum User
    edited July 2015
    thanks for all
  • Altair Forum User
    Altair Forum User
    edited August 2015
    I found code some code like this you can use for any panels selection
        hm_pushpanel 'project'
        set id [hm_getcolnumber {project} 1 ]
        hm_setcollector 'project' $id 'comps'
    Thanks and Regards
    P.Varthamanan
Welcome!
Welcome!
