Hi HM users,
I often have to use many clicks to go to USER panel menu( go to Utility > User). Do you have any macro or how to set shortcut key to access this more quickly?
Many thanks.
Hi
you can assign a shortcut key for this with command:
hm_process_macromenu_key 103
Hi you can assign a shortcut key for this with command: hm_process_macromenu_key 103
Thank you Tinh but it only worked when we already stayed at Utility browser page. If we stayed on other panel such as Translate or Automesh, it would not work.
I saw this command in cmf file: *setactivepage(5) but I could not set shortcut for this.
