How to rectangle multiple select surfaces in InspireForm?
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi HF experts,
When I organize surface into Die/Punch/Binder with InspireForm 2019, I have to manually select each single surfaces.
It is quite inconvenient.
May I know which setting allows me to select with rectangle mouse so that I can choose multiple faces faster?
Thank you.
1 - 1 of 11
    User: "Junta_20361"
    New Altair Community Member
    Updated by Junta_20361
    hi alpha,
    In IF 2019 versions, you cannot do that command.
    In IF 2020, you can do that easily by holding SHIFT button and LMB click and drag.
