simsolid Software CPU usage is low
Hi...attempted now with 4.4GHz for all centers in support. Indeed, got temps up to 70°C, yet didn't bring down the Vcore bend yet, went up to around 1.13 - 1.14 while it topped around 1.09 before the OC. Had temps up to 62°C there before as of now, so not that a lot of an expansion in any case. I mean we're talking 29.4% increment of clock rate here, which is parts. My fps consistently have been 40+ now, just once I saw a 35 while sprinkling a MiG and taking a screenie of that (can't peruse the fps in any case while flying, the text style tone is totally repulsive and it's size excessively little). With mirrors off it goes up to 70+. Prior to OCing, this was around 22-25ish and ~35-40ish w/o the mirrors. Totally insane if you were to ask me, not so much as a third more in CPU check bringing about double the fps... In facades I had 90 generally, frequently more than 100. Never had that on the 1080 OCing my CPU. At the point when it was at 70+, it was a lot of as of now.
