Hi All,
I want to import a step file into hypermesh and by mistake the are some additional edges in the model:
how can I avoid this?
Thanks! :-)
how can I avoid this? Thanks! :-)
The lines you have pointed looks to be shared edges. this comes when two surface meets.
If you want, you can do geometry cleanup to suppress these edges.
Thanks
Rajashri
