Very simple part fails to mesh with the new option "Use advanced meshing with SimLab"
File attached.
Please advise
Hello Uri,
When you hit run it opens up SimLab window where you can perform mesh controls with different perspective. After Mesh control, you create surface and volume mesh. When you hit save and exit, mesh will be loaded to inspire cast and you will see it moved to further stage. See attached image.
Thanks
It was a license problem.
Solved
