I've got the following problem.
In the design of a quadrifilar helix antenna i'm using a single voltage source to feed each helix arm. So I've 4 voltage sources. By changing the phase of each source I can control the pattern characteristics.
At the moment when a change the phase shifts I ri-simulate the whole project, probably this is useless, and I could save time.
On the other hand since i'm interested in considering two control phase sets (one for RHCP and one for LHCP),i'm using two files, with the same geometry but different excitation phases.
Please, can someone suggest me how to avoid risimulation and how would be possible to get the results for the two sets of control phases in the same project?
Thank you
Regards
Claudio
