I am working with this circuit in flux, to obtain the impedance in a frequency range.
However, I also need the resistance and inductance values, and when comparing the resistance obtained from the joule losses with the real part of the impedance of each solid conductor they are not matching. The same happens with the inductance obtained doing flux/current and the inductance obtained from the imaginary part of the impedance.
It is something not working properly with capacitors?
Moreover, when I use the obtained Resistance and inductance values and solve the circuit analytically, it does not match with the source impedance.
I put the model attached if you want to take look of how I have defined all and if you see any mistake, I would be very grateful.
Thank you,
Yerai Moreno
