Clara,To assign a wild card in the file name in the Automator Visual Process perform the following steps:First upload the workspace in the server library.Create a Visual Process, add a database input and use a wild card in the path.Add a workspace object to the canvas,Connect the database input to the workspace. In the workspace property pane, select the database input in the File name list.I assumed when you used the csv fine in DPS, you used the delimited text option. If you used the text option in DPS, then in Visual Process you should use File Input object instead of Database Input object.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840-------------------------------------------------------------------------Original Message:Sent: 02-25-2019 06:42 PMFrom: Clara BonaccorsiSubject: Data Prep Studio input path wildcardHello all, my question is about inputs to Data Prep Studio and wildcards in the file name.Q:In Data Prep Studio, when defining an input source file path, is it possible to utilize a wildcard in the path? For Example, a file may be calledTrialBal_123456ABC.CSVorTrialBal_789012XYZ.CSVAre wildcards allowed in the pathname like in the same way they are allowed in Monarch project source path names?I want Data Prep Studio to find any file beginning with 'TrialBal' and ending with '.csv' without renaming the source file.Thanks in advance!------------------------------ClaraBusiness AnalystIL------------------------------"
Thank you. It will be several days before I try this out but I'll let you know how it goes!
Thank you. It will be several days before I try this out but I'll let you know how it goes! ------Original Message------Clara,To assign a wild card in the file name in the Automator Visual Process perform the following steps:First upload the workspace in the server library.Create a Visual Process, add a database input and use a wild card in the path.Add a workspace object to the canvas,Connect the database input to the workspace. In the workspace property pane, select the database input in the File name list.I assumed when you used the csv fine in DPS, you used the delimited text option. If you used the text option in DPS, then in Visual Process you should use File Input object instead of Database Input object.RegardsMo------------------------------Mahmoud AbdolrahimSenior Implementation & Integration EngineerDatawatch CorporationMA(978) 935-3840------------------------------"
