When trying to create a Etool box component for a study of the efficiency map, I get always an error and it never creates the model.
I follow the guideline but it does not work
I need help please since it is urgent
you should have only one pole represented if you're using previous versions. Otherwise, in the latest versions it should allow to run if you have two poles represented.
Can you check also if you have wrong periodicities defined ?
Cheers
I think you need to use the latest versions to be able to generate Femt component for two poles. How many poles are represented in your model ?
