I'm investigating different software tools for modal, and other types of analysis, with a focus on Design for NVH. I'll say I'm not "an analyst" but seem to be heading down that path somewhat.
At first, Inspire was used, as we have an Altair evangelist here and he recommended it to our design department. This didn't seem to have a complete set of tools but does to basic modal with a powerful solver in the back end. Next, I tried Simsolid as it seems to have more tools available for understanding NVH performance, while still being relatively easy and doesn't require full analyst level understanding and tools.
There seems to be quite a difference in the modes calculated, eigenfrequencies. The part I'm using is a three piece welded assembly that is fairly simple (essentially cantilevered beam) as far as welded sheet metal parts go. I believe I set up the constraints similarly, with grounded bolts in Inspire and immovable inside surface of the bolt holes in Simsolid and similar contacts where welded.
The major difference seems to be the first mode, being up to ≈16% different. The higher modes are typically closer, but some are ≈10% different, with most being ≈5% or less. I would accept 5% personally, but the first mode is concerning to me. When the solving settings in Simsolid are changed to 5 passes with high refinement, the differences are larger (lower 1st mode frequency, ≈20% difference) than when standard 3 passes with standard refinement is used.
Inspire is the more trusted result right now because our evangelist knows and trusts Optistruct solver. I liked that Simsolid has more analysis types available, but it is largely unproven here.
Short of building a part and testing it, does anyone have any experience with what solver is more accurate in general?
Any other feedback on maybe I didn't constrain it similarly like I thought or other potential areas for improvement?
Are there other recommended tools for NVH dynamic analysis types that would be better than these? Do I need to go all in on hypermesh, optistruct, others?
