Arduino compile error
User: "uzamad"
Altair Community Member
Updated by uzamad
Just installed altai embed and tried Arduino uno project Led Blink.
In code Generation when I click compile, lot of errors are generated. At last line the error is
avr-g++   is not recognized as internal or external command
What could be the fault?
The circuit arrangement is as follows:-
arduino config block
square wave generator
Arduino Uno Digital Output
1 - 3 of 31
    User: "Sreeram Mohan_20248"
    New Altair Community Member
    Updated by Sreeram Mohan_20248
    Can you send us a snapshot of the error log ?
    --sreeram
    User: "João Marabisa"
    Updated by João Marabisa
    I have found this topic because I was having the same error! For those who are intending to use Arduino in Embed, basically you should install Arduino IDE before Embed.
    I already had Embed installed and then I installed Arduino: Got the avr error on Embed (if there is some way to select after installation, would be nice).
    Anyway, I've tried to uninstall Embed and Install it again: On the installation procedure was not finding Arduino IDE directory.
    So I've uninstalled both, installed Arduino and then Embed: With that, Arduino directory was found on installation procedure and now is compiling. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    The install guide while installing Embed in fact prompts the user guide to say this but as like any other installs one would just click on next -next and be in a hurry to get to finish the install :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    --sreeram
