Hi everyone
I am trying to mesh a stp file (attached). First of all, is it possible to mesh the surface with trias and then mesh the inner solid in 3D with tetra elements, or do you think the geometry does not enable this method ?
Then, I have tried 2D tria mesh et 3D tetra mesh, with different size elements, but it seems that Hypermesh always gives the same meshing as in the initial stp...
Finally, does anyone have an idea of how to clean up this geometry in an efficient way ?... does anyone work in the biomedical field here and has already faced the problem ?
Thanks in advance for any help..
