Is it possible to crop voxel models? For instance, I have a full human model, but I am only interested in the torso. Cropping out the limbs from the full human model would reduce memory usage and simulation time, so how can one do that in FEKO?
Hi Daniel
Did you create the model in Feko and mesh with Feko?
If you import a voxel mesh (*.raw). this will be converted into a triangular mesh. Triangles can be selected and removed.
