Helo everyone.
I have a force define as action/reaction and line of action translational:
This force will be applied during a define displacement. Once the defined displacement will be reached the force will not be applied anymore.
In order to check the correctness of the code I would like to plot the force applied and displacement of the two markers vs time.
The goal is to check if the force stops as defined in the code.
Should I define an output command in order to plot it?
Best regards.
