I have 150 list of components ( one comp per comp collector), I have to write out seperate *.stl file for each component with Component Collector name followed by Materialname and thickness
i.e Comp Name: Wheels, Material Name -Steel; Property Name - Wheel_Shell with Property values, E, V & Thickness = 3 mm.
Need to write filename of part: Wheels_Steel_3mm
