Hi all,
I am trying to calculate the value of added mass in Hypermesh using Check Elems Panel. Please see that I am using LS Dyna user profile.
When I click on the element in question, I get following value
But when I click on check elems panel. I get following message on status bar
There is difference in two vales of added mass. This may be small. But it becomes significant when I consider an entire assembly instead of single element
LS Dyna added mass value is similar to that of the status bar message. I would like to know the reason for the diference in values.
This is needed because I am trying to write a script to calculate added mass and the api I am using is giving the wrong value of added mass (From 1st Picture).
Thank you in advance for you help and support.
