I'm very new in this forum.
I have calculated the torque in the mechanical set of the sun, in this planetary magnetic gear. In the real model there is 3 planets so I'm using a 120° periodicity.
My question is: The torque that Flux has calculated corresponds to the hole sun? Or just to the represented sector? In this second case, I should multiply the torque x3, right?
By the way, I'm using Flux3D 19.1
Thank you in advance for your time
Andres
_______________________________
Update 28.09.2020
This is an update to my previous post.
I have simulated the same structure but with 6 planets instead of 3.
Flux calculates now a torque ~1.8 times bigger than before in the mechanical set of the sun.
So I guess that, when a periodicity is used and only a part of the mechanical set is represented, Flux gives you the torque in the hole mechanical system, and not only in represented part. I have not to multiply xNumber_of_planets
I would really appreciate if anyone could confirm this
I don't understand how this forum works. I tried to answer to myself (instead of edit my previous message) but there is no button 'answer'. I can't actually answer nobody.
As I said, I'm very new here. Thank you for your understanding.
Regards
Andres
