Help on designin a machine
Hello all,
im a flux 2D beginner and im working on a project where im trying to find the right design for a machine in flux 2D.
Can you guys give me some tips how to write the script because right now i'm designing it manually with the geometry options but im having problems changing the form of the permanent magnets (for example) beucase then i need to redesign it through the geometry options.
Any tips from your side on how to do the crossing from manually design to a valide script ?
Thank you for any help.
In Flux you have the possibility to parametrize your geometry. This mean that you a geomtric parameter and if you want to change the shape of the magnet for example you need just change the value of the geomtric parameter. To learn how you can use it, there are examples on the supervisor. (technical tutorials>> select magneto static application: sensor), this allows you to see how we use the parameters in Flux.
About the python script, attached some document that can help you.
Best regards.
