Altair RISE
Nominate Yourself Now!
Deleting suppressed edge
User: "Yusuf elmas"
New Altair Community Member
Updated by Yusuf elmas
First of all, I have a node on surface which is so close to a suppressed edge on the same surface. When I try to add a fixed point using the node that I mentioned before, the program create a fixed point exactly on the suppressed edge. So is there a way to fix this problem?
<?xml version="1.0" encoding="UTF-8"?>1262A127-7BD7-48B3-8ABE-D7EBF12E2E84.jpeg
1 - 1 of 11
    User: "Adriano_Koga"
    Updated by Adriano_Koga
    Are you using what function? project?
    have you tried changing a little bit the tolerances in the options menu? 'O' shortcut in the keyboard.
    maybe decreasing the cleanup tolerances for geometry and mesh could help.
