I am attempting to run the OS-1000 tutorial and have followed it exactly, however I keep getting the error
*** ERROR # 1908 *** Case Control data LOAD=2 is not referenced by any bulk data relevant for used subcase type.
can you check if your forces are inside the correct load collector?
It is complaining basicaly about the Load Collector 2 being referenced, but it seems to be empty.
So probably, your forces were not created morrectly, maybe.
