Unprojected nodes will not be associated to any surface, so you can check projected nodes by select nodes > by geom > surfs
and then reverse the selection.
if you want a macro, it includes just a few commands :
*nodecleartempmark
*createmarkpanel surfs 1 "Select surfaces:"
*createmark nodes 1 "by surface on mark" 1
*createmark nodes 1 reverse
*nodemarkaddtempmark 1
