I want to visulaize displacement in each frame in hyperview. but when i move the different frames the color map and the legend is not changing.
Any idea how to fix that?
Hi moeen
click > legend > edit legend >type >dynamic scale
Hi moeen click > legend > edit legend >type >dynamic scale <?xml version="1.0" encoding="UTF-8"?>
This does not worked. I am running a linear elastic analysis
Yes its true , since results of static analysis doesn't changes with respect to time ,dynamic results are not available .
Dynamically changing the legend for a static analysis makes little sense. It makes much more sense to display the contour plots dynamically.
You can do that by turning on the contour panel-> display-> interpolate colors. (see picture)
Best regards,
Mario
