Automatic report generation by tcl/tk and API in hyperview
User: "Zaily"
Altair Community Member
Updated by Zaily
hi, guys!
In hyperview, I want to generate the report by tcl commands. But in the class hierarchy, I couldn't find the way of defining the handle about ppt (hwIPPTPublish_handle). It is appreciate for you to help me solve this problem.
Thank you  very much.
1 - 5 of 51
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Its in the session class. Attached is a sample script that shows using PPTPublish handle
    hwi GetSessionHandle sessionH
    sessionH GetPublishingHandle pub
     set pfadPPT 'D:/tmp/test.ppt'  catch { sessionH ReleaseHandle } catch { pub ReleaseHandle } catch { ppt ReleaseHandle } hwi OpenStack hwi GetSessionHandle sessionH sessionH GetPublishingHandle pub  pub GetPPTPublishHandle ppt  ppt SetDestination new  ppt SetPathOnDisk $pfadPPT  ppt Publish  ppt SaveLinkedPPTPresentation $pfadPPT  ppt CloseLinkedPPT   hwi CloseStack
    User: "Zaily"
    OP
    Updated by Zaily
    Hi, Livil Lyle.
    Thanks for your answer. I also thinks that it is in the session class. But I could not find this command--GetPPTPublishHandle. When I try to use this command, the system shows the message that 'Object named: sessionH (of type hwISession) could not find requested method: GetPublishingHandle. Or the method was called with incorrect arguments.' The version that I use is 14.0. I have no idea how to solve this problem. It is appreciate for you to help me in this aspect.
    User: "llyle_20499"
    Hi Shi,
    I didn't have this issue in Hyperworks 14.0.133.
    Livil Lyle
    User: "Zaily"
    OP
    Updated by Zaily
    Hi Livil Lyle,
    When I try it in the version 17 again,  it is ok. Thank you very mush.
    Shi Feng
    User: "Altair Forum User"
    Updated by Altair Forum User
    I am very new to TClLfunction coding below is code which i modified according to my requirement  now  I want to directly publish the images to PPT  directly, i tried including above commands (macro is not pasted) but it is inserting picture for one loadcase I have 4 loadcases, is there way to make below macro work for mulitple loadcases.
    # HyperView and then save it under the current working directory.
    # THIS MACRO CREATES PUT PICTURE CURRENT FOLDER
    # THIS CAN TAKES STRESS & DISPLACEMENT PLOTS
    # USER NEED READ MACRO AND UPDATE INPUTS IN CONSOLE WINDOW
    # USER HAVE BEEN FLEXIBILITY TO SELECt THE PARAMETERS
    # IT TAKES PICTURE FOR DIFFERENT LOADCASES AT DIFFERENT ANGLE NOW It iS SET TO 45
    namespace eval ::compQuery {
    proc ::compQuery::GetcompVar { args } {
        set t [::post::GetT];
        #set he [string map {. '' ' ' ''} '[clock seconds][expr rand()]']
        ## Releasing all handles
        hwi ReleaseAllHandles;
        hwi OpenStack
        ## Getting the session, project handles along with current working directory
        hwi GetSessionHandle sh
        set dirName [sh GetSystemVariable 'CURRENTWORKINGDIR']
        sh GetProjectHandle ph
        ## Getting the page handle and the no. of pages in the session
        for {set i 1} {$i <= [ph GetNumberOfPages]} {incr i} {
            hwi OpenStack
            ph GetPageHandle pgh$t $i
            pgh$t GetAnimatorHandle animh$t
            ## Getting the window handle and no of windows in each page
            for {set j 1} {$j <= [pgh$t GetNumberOfWindows]} {incr j} {
                hwi OpenStack;
                pgh$t GetWindowHandle wh$t $j
                wh$t GetViewControlHandle vh$t
                ## Making sure the client is Animation and that the window is not empty
                if {[wh$t GetClientType] != 'Animation' } {
               ::hw::ShowMessage 'Animation Client is not loaded on pg${i}win${j}, continuing with the next one'
                   hwi CloseStack;
                   continue;
                   if {[wh$t IsEmpty] == 'true' } {
                  ::hw::ShowMessage 'pg${i}win${j} is empty, continuing with the next one'
                  hwi CloseStack;
                  continue;
                      wh$t GetClientHandle posth$t
                      ## Getting active model handle along with result and contour handles
                      posth$t GetModelHandle mh$t [posth$t GetActiveModel]
                      mh$t GetResultCtrlHandle resh$t
                      resh$t GetContourCtrlHandle ch$t
                      ch$t GetLegendHandle lh$t
                          ## Setting datatype, datacomponent and the layer
                          set dType [ch$t GetDataType]
                          ch$t SetDataType $dType
                          set dComp [ch$t GetDataComponent]
                          ch$t SetDataComponent $dComp;
                          set layer [ch$t GetLayer]
                          ch$t SetLayer $layer
                          set System [ch$t GetResultSystem]
                          ch$t SetResultSystem $System
                          set Position [lh$t GetPosition]
                          lh$t SetPosition $Position
                          #set Position [lh$t GetNumericFormat]
                          #lh$t SetNumericFormat $NumericFormat
                          ## Finding the subcase list and going over each subcase to set the desired query items
                          set subcase_num [resh$t GetSubcaseList]
                          foreach subcase $subcase_num {
                                  resh$t SetCurrentSubcase $subcase
                                  set simu_num [resh$t GetNumberOfSimulations $subcase]
                                  for {set k 0} {$k < $simu_num} {incr k} {
                                      set simu_label ''
                                      set simu_label [resh$t GetSimulationLabel $subcase $k]
                                      resh$t SetCurrentSimulation $k
                                      tk_messageBox -message 'ENTER ONE STRESS, TWO DISPLACEMENT'
                                      puts 'ENTER ONE OR TWO'
                                      set x [gets stdin]
                switch $x {
                                ONE {
                                    ch$t SetDataType 'STRESS'
                                    tk_messageBox -message 'ENTER vonMises,Tresca,P1 or P3'
                                    puts 'vonMises or Tresca'
                                    set i [gets stdin]
                                    switch $i {
                                    vonMises {
                                    ch$t SetDataComponent 'vonMises'
                                    Tresca {
                                    ch$t SetDataComponent 'Tresca'
                                    P1 {
                                    ch$t SetDataComponent 'P1(major)'
                                    P3 {
                                    ch$t SetDataComponent 'P3(minor)'
                                    ch$t SetLayer 'Max'
                                    ch$t SetAverageMode 'SIMPLE'
                                    ch$t SetResultSystem 0
                                TWO {
                                    ch$t SetDataType 'DISPLACEMENT'
                                    ch$t SetDataComponent 'Mag'
                      ch$t SetEnableState true
                      lh$t SetVisibility true
                      lh$t SetPosition Topleft
                      lh$t SetNumericPrecision 3
                      lh$t SetNumericFormat    fixed
                      lh$t GetMinMaxVisibility true
                      posth$t SetDisplayOptions contour true
                      posth$t SetDisplayOptions legend true
                      posth$t Draw
                      pgh$t Draw
                      ##vh$t FitAllFrames
                      set ::compQuery:::rotAngle 90 ;
                      for {set i 1} {$i <= [expr 360/$::compQuery::rotAngle]} {incr i} {
                                        vh$t RotateRight $::compQuery::rotAngle;
                                        ##vh$t Fit ;
                                        posth$t Draw ;
                                        sh CaptureScreen JPEG '$dirName/page${i}win${j}subcase{$subcase}tstep{$k}.jpg' 70
                                        #puts $filepath ;
                              ::hw::ShowMessage 'Images are successfully captured and are located at: $dirName'
                              hwi CloseStack;
                       hwi CloseStack;
            hwi CloseStack;
