Problems with Legends
The text of the Legend on my Hyperview looks too big.
Is it because my screen is 4k?
I am using workstation with quadro P2000. The drivers are all updated.
I have already tried the smallest text size for the Legend but it doesn't help.
Anyone had this problem?
For sure, could you test your card with another normal monitor?
0 -
This is actually getting weirder as I cannot drag the hyperview to my secondary screen. The hyperview snaps to the edge when I minimized or reduce the window size and stays that way until I maximize it again.
Update:
Opening the hyperview right to the second screen (1920x1080) solved the problem. If this is the case, how will I solve the problem in my 4k laptop?
0 -
Which version do you use?
0 -
version 17
0 -
Maybe try with version 2019.1?
0 -
Haven't tried that version yet. And I believe we don't have that version. So that means, there's no work around for the 4k monitor?
0 -
try to switch in the property panel (right click HV icon) -> Compatibility -> DPI scaling to system.
This helps for me in other applications, i can't try it in the moment for HV.
Best Regards,
Mario
