I am wondering why I cannot mesh the LA25 Center Plate and LA25 Doubler Plate surfaces (see attached picture).
I tried playing with mesh sizes but it's not helping.
What are the reasons why surfaces are not meshed?
There are overlapping surfaces in component LA25 Center Plate which you could split using Shift + F9 and delete the overlapping components and then try to mesh.
Note that geometry cleanup should be done before meshing.
Thank you
