I am using a laptop with Ryzen-7 after all installation which is needed for nanoFluidX the product is not opened.
There is any other process for installation for CPU laptops?
Though NFX does now run on Windows, it still requires capable NVIDIA GPU, as the solver runs on GPU.
Which is your graphics card (GPU)?
https://help.altair.com/hwcfdsolvers/nfx/topics/nanofluidx/faq_simulation_environment_r.htm
Though NFX does now run on Windows, it still requires capable NVIDIA GPU, as the solver runs on GPU. Which is your graphics card (GPU)? https://help.altair.com/hwcfdsolvers/nfx/topics/nanofluidx/faq_simulation_environment_r.htm
AMD Ryzen 7 5800HS with Radeon Graphics
You need NVIDIA GPU with at least CUDA compute 3.0 or higher - will not work with Radeon.
