after running solver the post feko says fek and bok files are missing...puzzled how to rectify that..although these files are visible in directory
Hi Akedar
How are you running Feko?
For example, running on a local machine only.
Or copying the model files to a remote machine and solving there, or using remote launching.
If you manually add the model to a fresh instance of POSTFEKO, does it load then?
Which version of Feko are you using?
