Difference between off and disable
I have to constrain a component in hypermesh with LS Dyna interface, but I can't understand the difference between off and disable when I have to constrain a degree of freedom.
Could anyone explane me the difference?
I attached a picture.
Thanks in advance
1 - 2 of
21
OFF is just used by HM, saying that 'you have not selected any option' and this field will be left 'blank'.
The other options are related to the Solver choises/options that you have. These are the values (0 or 1) accepted by Dyna. If it is blank, then there are some defaults, and you end up in the first case.
Many ,Many Thanks Adriano.
Regards
