Dynamic block factory creation is not worded when I use GPU CUDA Solver. New particles are not created. CPU or GPU OpenCL Solver is working well but much slower.
Hi Fang,
Could you confirm which version of EDEM you are using? I'd recommend trying the latest 2022.3 version as this may be resolved there. Also its best to use the GPU CUDA solver as the OpenCL solver will be discontinued in future versions.Regards
Stephen
Hi Fang, Could you confirm which version of EDEM you are using? I'd recommend trying the latest 2022.3 version as this may be resolved there. Also its best to use the GPU CUDA solver as the OpenCL solver will be discontinued in future versions.Regards Stephen
Thanks a lot.
I uses EDEM 2020.0 , version 8.0.0 .
Thanks a lot. I uses EDEM 2020.0 , version 8.0.0 .
Just to conform the block factory support for CUDA GPU was first supported in 2022.1 however I would recommend updating to the latest 2022.3 version if you want to use this feature.
Regards
