how to go through this?
Hello Shifali,
Check if the property is being exported to your solver deck. In HyperMesh, you can use the Entity State Browser:
When exporting, if something has the "Export box" unchecked and you select custom export settings, it won't be in your solver deck:
Another thing to check is if your CBEAM elements have direct property assigned to it.
Organize all CBEAM elements that should share a PBEAM property into a new Component:
See if the Direct Property box is checked. If so, uncheck that then try again.
Kind regards,Paulo Libório.
