what are the methods to make a simulation faster?
Hi Gabriel,Which product are you using? Faster can be very methodology dependent although would say there are typically techniques which are common.
Making sure you are running at an appropriate time-step, ensuring that you are saving the correct amount of data and not saving too much, faster hardware (hdd, CPU or GPU) makes a difference.
Regards
Stephen
