Hello dear all.
 probably my next question is quite easy or even was already asked before.
 I already searched for many ways but non of them work.
 Look i have a simple tube but one end is covered, i am performing some compression analysis but i want to do a proper mesh.
 Therefore, using the automatic tetra mesh was not the best one, and now i am trying to create a more decent mesh.
 I want to do simple bricks or cubes in one part of the tube then of course those bricks must be placed or imprinted on one part of the covered tube. but i don't know how to do that because there is not connection on the meshes.
 such tube with on end covered is composed of one single material
 Let me tell you that i already tried to split the body into two and tried to mesh them but my problem persist.
 Also i used the boolean in order to set a shared face for the two bodies.
 By the way i am trying to avoid meshes with kind of wedge like radial meshes.
 Plase take a look at the image
