How to simulate multiple transmitters and results at multiple heights simultaneously using WinProp?
User: "3mz"
Altair Community Member
Updated by 3mz
hi
I want to obtain simulation results for multiple transmitters and multiple heights by executing ‘'run pro'’ once. When attempting to set multiple heights, I inputted multiple values within the red box, but I still only obtained a simulation slice for one height.
What I'm aiming for is a situation similar to the one shown in the image below.
thanks
1 - 1 of 11
    User: "Zeina"
    Accepted Answer
    Updated by Zeina
    Hi Zeina
    These days I've been applying for a student license, but it hasn't been approved yet. Once approved, I will update my WinProp version to 2023.1. I tried entering multiple heights to obtain simulation results for various heights, but it failed. Below is the exported project.
    Best Regards,
    wuyoubiao
    Hi Wuyoubiao,
    I can view the three height results you have requested when rerunning in v.2023.1:
    A small check: after you are re-running the prediction simulation with multiple heights, are you refreshing the results displayed by clicking on Power from the results tree? This updates the results and the heights' list.
    If you still do not see the different heights in the drop-down list, then updating would probably solve the issue.
    Best Regards,
    Zeina
