I merged the components of the frame with boolean solid edit and then i meshed the geometry with tetramesh. I want to make a modal analysis.
Please find the attached pdf for your reference.
You can also check the tutorial form help section: https://altairhyperworks.com/hwhelp/Altair/2019/help/os/topics/solvers/os/modal_analysis_setup_r.htm?zoom_highlightsub=modal+analysis
I Have read this tutorial and i know the process for modal analysis.The problem is that i merge the components of the assembly with boolean function...something is going wrong.It would be helpfull if you could explain to me the output error.
You have not assign an property to you CTETRAs. The third block in your CTETRA card is '0', which is not allowed.
