Hi there,
I'm trying to connect my composite models together between blue component and black component by using area connector -> hemming,.
However, i modelled the thin red layer between those two components for adhesive definition (the reason why i do not use adhesive connector from thr first place is due to mesh size neccessity since the thickness of adhesive layer is relatively thin compared to other components while i would like to control the mesh size if adhesive component).
My approach was that in area panel choosing hemming type connector where is the location of elements is upper-red layer connecting to blue component and lower-red layer connecting to black component. The connector failed to realise which i do not know why, please advise.
Thank you.
