How can we find the resistance of a coil in Altair flux?
To compute the resistance of the coil in Flux you must give some information of the face region (volume region in case of Flux 3D) like the material and fill factor. Once these information’s are given you do check physics and you edit the coil conductor you will get the new value of the resistance.
Best regards.
