Inspire_Number of CPU cores?
Hi I wanted to know how I should set up the Inspire run option in order to get full performance on the software
I have a Lenovo Legion Y540
processor: Intel Core i7-9750H CPU 2.6Ghz
RAM: 16Gb
Graphic Card: Nvidia GeForce RTX 2060
My main doubt is that the computer has 6 core processor but 12 logical processors
So I don't know if to put 6 or 12
Thanks
Agustin
1 - 3 of
31
Updated by SouravDas0306
Hi Agustin,
I would suggest you to use maximum for better performance /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Regards
Sourav
Hi Agustin ,
You can go with 12 core Processor , you system configuration is sufficient to have a full performance on the software. Inspire uses maximum available cores from the machine,if it is in the default settings.
Sourav
